I've been running the engine for about 15min about once a month since autumn. been too busy to get it ready for inspection.
it's been a long winter here in the northeast..
Anyways,
today as I always do, I checked the oil level but also coolant.
The coolant seemed low so I opened the fill cap and it popped off with a good deal of pressure. immediately the coolant level began to rise quickly gurgling back up to the "fill" line.
I ran the engine maybe a bit longer than normal because it was very nice outside and it may have been longer than usual since the last time it ran it.
I drove it around a bit, the temp got to about 200 so I went back to work for about 10 minutes to let the fan kick on(it's the use it or loose it attitude).
anyways, when I got back the temp was 240 so I turned the engine off. the coolant level was at full when I switched the engine off.
I know the fan has worked before.
could sitting prolonged periods cause these issues?
What could be wrong?
Why did the coolant reservoir have so much positive pressure after a month of sitting?
something maybe I should mention is that I last parked it with the front about a foot higher than the rear.
Anyways,
