scottmandu
- 35
- 28
- Texas
The fan switch should be RD-5-8218-0P
The trinary switch should be RD-5-11064-0
This is obviously a gen1 in the picture. Anyone have a schematic for the gen2 or are they wired the same?Here is a wiring diagram I had, not sure if this exactly for your unit, regardless everything should be wired the same. This schematic looks like it may be for a setup using 2 seperate pressure switches. One would be a high pressure switch which is used to turn the condenser fan on when the system pressure reaches a a preset pressure limit. The other switch is a binary switch switch which prevents the compressor from comming on if the system pressure is too low and turns off the compressor if the pressure is too high. Another option is to use a trinary switch which combines these two functions into one switch. Either way the wiring is the similar. Regarding the switch itself there is nothing special about the correct LMTV part, you can use any generic AC pressure switch, I purchased mine from coldhose.com, I used the trinary switch. Also I didn’t have the factory harness and didn’t wire the fan portion of the trianry switch in series with the fan, I didn’t want the motor current running thru the switch, rather I used the switch to control the condenser fan relay ground.
Hopefully this helps.View attachment 725225
I was told something different, they could be manufactured, 6 piece order $6500 each.My local Red Dot dealer says corporate told him the inside units are an OEM and non stock item that can not be ordered directly at this time but may change soon.
Still working on it.
NiceI have sold a few Hmmwv Kits to customers with M35A3 trucks. Same engine.. Attached are few pics..$1,250.00
You have to make your own A/C compressor bracket..They told me it was too cold! Ran it on low all the time. Customers have adapted it to M923a2, M923, M35A2, and many others. Cooled my M1044 Great, Wife complained it was too cold!, Turn it down! She demanded..Love it!
Kevin. decodeme@verizon.net
I have everything expect the evaporator box for the cab.Do you have or know of someone selling a complete A/C kit for an M1083a0 (Cat 3116)?
I am going to ask again........ anyone have the wiring diagram for a Gen 2?This is obviously a gen1 in the picture. Anyone have a schematic for the gen2 or are they wired the same?
Thanks
Sent from my iPad using Tapatalk
