djhenley
- 1
- 1
- Clanton, Al
I've been not dealing with this issue for a few years! When primed fires up faster than a UFO, but let set overnight... maybe 24 hrs and it looses prime.
removed tank, cleaned it with industrial steam cleaner, dried it out, removed pick up tube and it had hole at support few inches from bottom of tank, had it brazed. replaced old canister with dual filter bracket / filters, replaced all fuel lines to lift pump, new lift pump, changed injectors with reportedly rebuilt injectors, new relief valve.. outlet of injector pump ? bypass, over the past 2 maybe 5 yrs. today said I will find problem, pulled tank off again pressurized line from lift pump including lift pump all the way including pickup tube. After blowing all the fuel out could hold finger over end of pickup tube and raise to 25 psi with all this under water in a drum saw no bubbles! thought i had not checked suction tube well enough, when i go to crank it after setting, say 2 day will not attempt to fire... should it run and pull filters empty? I even put a cut off valve thinking that would help and open it just before trying to crank.. no good HELP
Cummins 8.3L
Cummins 8.3L
