- 463
- 262
- 63
- Seville, OH
Just to be clear this price is if you ship your diff to MTP for them to install the R & P into. You still need to take your truck apart yourself, this is not the price of them doing the whole truck which is $5575 for 2 axles. The diffs I sell are NEW so bearings and pinion seal are new, it is almost a equal price plus your truck is not down for a month, plus you then have spare diffs to do something with later.Why would anybody want to have gearsets made or install takeouts when brand new Meritor gearsets can be installed by MTP Drivetrain for $1750 per axle?
I guess you'd have to see the truck. I've stripped the cab down completely inside for one thing and there is/was minimal wear on any areas where you would expect to see it. No accumulation of dirt etc under the instrument panel or under the fuse box. Everything in the engine area looks typical of a used low mileage vehicle.How do you know it only has 3700 miles on it? It may have gone through at least one rebuild where they did not do the seals or is that something that is done each time? You may not have to, but I have seen many things taken apart and put back that the seals then developed leaks. I would take it apart carefully, clean everything and with lube on the seals put it back. You may be OK. My truck is a 94 with unknown miles so I will replace them. (My truck shows 1700 but is obviously much more than that)
Can your gear manufacturer connection make a torque biasing, or torque-sensing (“Torsen”) differential for these axles?Did we ever determine if a ring and pinion can be swapped in the original chuck? I have a contact at a gear manufacture that is willing to make custom sets..
I believe he convinced Meritor to make a batch.... or he bought a rusty one like Steve Showed and then sent the gears off to a known gear making corp. to make a 100 sets. Aka..... they are not out of anything..... they are brand spanking new.What are the 2.87:1 diffs out of?
