Mike944
- 3
- 8
- Haddam, Connecticut
Hey everybody,
1971 M35A2, LDT-465-1C engine rebuilt in '85. Currently has the 2-hole injectors (nozzle ADB-35S-124-7). They're not opening cleanly (some are dribbling at 2600, opening at 3000) and the spray pattern doesn't look too great.
Thinking about replacing injectors/nozzles. Seems like the 1-hole nozzles are widely available, and fairly cheap. The 2-hole nozzles are much harder to find and more expensive. Which one do i want, and why? (the WHY is really the question i'm trying to answer here)
So far, my only choices (in the 2-hole) are chinese ones at $100/set (last-resort option, IMO), or some mil surplus ones that i found from a seller in Germany at 68 euro each!!! Before i continue scouring the globe, i'd like to understand when the 2 different nozzles were used, and the advantages (and disadvantages) of each. I can't seem to find a thread on this exact subject.
Doesn't the multi-fuel engine NEED the 2-hole injectors to make the whole multi-fuel thing work? I run a mix of pump diesel, and 1-micron filtered WMO. Perhaps the 2-stream is really only needed to run on gasoline?
