Before we get started, I did read the -20 TM and the procedures provided (and illustrated) are for using a mega floor jack, not bottle jacks.
Most people here seem to use bottle jacks except for hardcore professional types.
I also searched the archives but as usual, my search key words and phrases may not have uncovered the best threads.
I understand the kind of cribbing needed *underneath* a jack or stands. My questions are related to the top of the jack.
In this deuce thread: https://www.steelsoldiers.com/showthread.php?152065-Jacking-up-Deuce-front-end-(from-the-frame)
there are excellent photos showing the bottle jack placement at leaf springs and other areas, but what I am concerned about, is jacking the pumpkin or axle ends with a bottle jack. It would seem to me, that the contact point of a bottle jack is too small, and risks damaging the pumpkin. I was surprised to see in these photos, no protective cribbing between the contact point of the bottle jack and the truck.
I may be overestimating the forces at work here, but what kind of wood cribbing would be sufficient to protect the pumpkin or axle ends for jacking with a bottle jack?
Plain, Home Depot grade pine might be too soft and split open while jacking, punching through to the pumpkin.
Bottle jacks lack the stability of floor jacks. With the proper cribbing, do you guys feel secure jacking the axles from the pumpkin with a bottle jack or do you just jack up each axle END and then slip the jack stands under the axle?
Sorry if I'm over-analyzing this, but there are some pretty powerful forces at work here and it's a safety item. Thanks.
