OK. I guess I have to go back a notch to the broken crank theory because its broken. I pulled the starter as part of getting it ready to come out and could tell that the flywheel is still connected to the rotor.
That is going to complicate getting the engine out a little.
Here are the photos:
Always check your connections on any new (to you) equipment!! Take all the lids off and check EVERYTHING. Several of these terminals were loose. Several terminals in the instrument cubicle were loose as well.
Your speed sensor should NOT look like this! It was also loose.
The engine looked pretty good from the outside.
Its dirty but not too bad.
I never like to see loose parts like this laying around.
Lots of this stuff was loose.
