- 7,409
- 2,503
- Interlachen Fl.
Ok starting this thread because we were derailing another.
Allen aka Florida AKM bought a nonrunner and looks like both the engine heads were removed at one time. We decided to remove the IP Head and yes the button was off but also the spring was broken for the plunger. Allen got all the parts needed to fix that and to keep a long story short we replaced the Head. All new filters, fuel and additive. Bypassed FDC. Checked working in tank pump and have some fuel flow at the head and center head plug. Checked the delivery valve was ok. Checked over flow valve and Allen said that to was OK. I know I got the fuel control in right and it is working free. Let the in tank pump work for a couple of minutes and check flow back at the tank and had some. Tried to start and no go so we tried some ether and no go. Checked air flow and air cleaner is breathing. I know I preach that cracking the injectors is not needed on the multi fuel but I cracked all injectors and had some fuel at all of them. Allen and I talked about the last Ambac rebuilt Head I have been saving for my Deuce if I or my son needs it. Allen said no keep it. So we are sticking with the old head and crossed fingers that it is able to produce the required pressure to pop the injectors. We had plenty of flow/ pressure at the bleed screw so I believe the secondary fuel filter over pressure bypass is closed and holding. To remove the IP head we used Gimpyrob's quick method of checking the # two exhaust valve was open looking through the engine oil fill hole. The rocker had some lash before we rotated the engine over to line up the Head mark for removal. After the Head mark was on the valve was open leading us to believe that all the valve train is set correct and working. We will double check that when we remove the valve covers next time we work on it or Allen does it.
