jeeves454
- 0
- 0
- Rexburg, Id
Does a manual transmission exist in a 5 ton such as a 923 or a 931? Or has anybody done or heard of a manual transmission swap? Thanks.
I have a 16spd semi automatic in my 923. Basically an air operated manual transmission. It can only be installed in a cargo or lwb truck due to the size. It is also alot of work. And can only be done behind the NHC250 but it does give it alot of advantagesDoes a manual transmission exist in a 5 ton such as a 923 or a 931? Or has anybody done or heard of a manual transmission swap? Thanks.
would say going from the 6 spd auto to a 10 or 12 spd manual also allow for faster mph with less rpm, or is the mph almost certainly controlled by the axle ratio? I'm not a fan of autos in anything bigger than a 1tn tck
if its fits in a 923a2, would it be silly and or impractical to think it would fit in the 936a2? yes, they are NOT the same truck, but plenty of similar or exact features/parts in the drivetrain, that would lead me think something other than a dang auto would work in the a2 wrecker.One of my friends just sold his bobbed 923a2 with an Eaton Fuller 8LL and rear locker. Besides being a very clean and well taken care of truck, the transmission was awesome. With G177s, he could cruise at 1700 rpm doing 70mph and get great fuel mileage. Then while off roading, he had such low gearing with the trans, that he never had to shift into low range. Truck had all the usual engine bolt ons and fuel pump modifications as well. For a stock motor truck, it ran amazing. Wish I had the money when he sold it. That was an awesome truck!
from reading through some other threads in the mod section, that seems to be the norm, compared to the 800 series. both models have their pros/cons. once i get back south, and get them home, ill climb under 1 and see what/where things mate up, and if i can find a 923a2 or similar in my area, ill check it out and compare measurements and locations of things. i think the local guard unit may still have some 900 series trucks.M923A2 and M936A2 are the same running gear and the same wheelbase.
The wrecker has PTOs on tcase and transmission that may be an issue.
The 8LL, is an Eaton Fuller 8 speed manual transmission is a low low reduction gear, thus the "LL" designation. There are many options from Eaton Fuller and other heavy truck transmissions. I believe my friend used the 8LL since its the shortest heavy duty manual you can get. There is limited space in the drive line due to the transfer case. I didnt take measurements off my friends truck but I know the drive shafts have to be modified to make a manual fit. He did not move the transfer case. I would also think you need to take measurements to make sure the manual trans can fit with a PTO, since you would need that for the front winch system. If you do go the route of putting a manual in a wrecker, please take a LOT of pictures. Ive never heard of that done before.if its fits in a 923a2, would it be silly and or impractical to think it would fit in the 936a2? yes, they are NOT the same truck, but plenty of similar or exact features/parts in the drivetrain, that would lead me think something other than a dang auto would work in the a2 wrecker.
lukes, the above question isn't directed just at YOU, but anyone that might shed a bit of light.
I'm hoping to have 2 a2 wreckers at the end of the month, 1 with a bad boom lift cyl and xmsn. if iv gotta get another xmsn, why not try for something other than a oem auto to stuff back in it.
edit: i can't tell from the google search i did of that 8LL, but is it a manual? i guess that should have been my first query
Red barn customs makes a weld unit and they have Detroit lockers for sale. Usmc had wreckers with lockers as well as their cargo trucksWait a second... Did you say "rear locker"?
Why, yes, yes you did. I am understanding that there is NO such thing for the 5 tons available. Can you explain further, please?
