- 1,394
- 178
- 63
- Frisco Texas
This is good to know for us Texans who buy corn like candy!
Do you grind it for animal feed....or a mash? Just curious. How many bushel?fwiw -- the M105 trailer has a 4k (lbs) CCC (corn-carrying-capacity), loaded level with the bed rails
That's a lot of corn for your still. Don't let the revenuers know you're increasing production. They'll tear your still apart and spill all your moonshine onto the ground!!fwiw -- the M105 trailer has a 4k (lbs) CCC (corn-carrying-capacity), loaded level with the bed rails
That’s one way of going deer hunting.fwiw -- the M105 trailer has a 4k (lbs) CCC (corn-carrying-capacity), loaded level with the bed rails
I feed a little whole corn to the cattle, it passes straight thru them, so the turkey & crow help break-up the pattiesDo you grind it for animal feed....or a mash? Just curious. How many bushel?
Tan M101A2
Used my steel stamp kit and hammered the Trailer Military ID and serial number into the tongue frame.
Data plates can be easily removed and/or swapped if trailer stolen.
Pic just shows a portion of what was stamped.
The steel the Military used is very high quality steel.
It was a LOT more difficult to imprint than any civilian trailer I’ve done.
Edit: Several hits from a 4 pound hammer didn’t imprint very deep on this steel.
Civilian trailers imprint fairly deep.
I know it needs painted.
Scheduled for early summer
Not a trailer, but this is the wrong place to drill.
WOW!
I see a structural failure in 3 - 2 - 1........
Whish I had your backyard LOLStarted taking apart a couple trailers today. One is an m101a1 with a very nice newer style cargo box and the other an m116a2 with the heavier duty frame. The cargo box is going on the a2 frame of course, should end up being a pretty decent m101a2.
View attachment 763107View attachment 763105View attachment 763106View attachment 763108View attachment 763109
Same with me.Whish I had your backyard LOL
