Duce half friends... I had a leak on bleeder at bottom of fuel filter... I removed filter canister and the carterage was very bad... got a new one installed it... filled as full of fuel as I could maybe half inch below full... I want crank tried a lot... recharged batteries... have 3/4 tank fuel... have 24 v both ends of fuse... when I turn on power with 1/4 plug out no fuel comes out. Should it flow? I dont hear pump run... l have bad hearing... what is my problem suggestions?
I m not skilled with sight ..it is awkard to find my way around hopefully i can see your responce thks david
