- 4,299
- 3,132
- Fort Worth, Texas
No HEMTT section on the forum, no love for them yet?
Anyway.. I'm in possession of an M977 that the previous owner had no desire to own or work on. I've been working on it all day and ended up in a crank no start situation that looks fuel related. I've got strong cranking but like I said no fire/start. I've got 1/4 tank of good diesel and the lift tube is good. I put my fuel tank cap with a schrader valve on the fuel tank and pressurized to 5 psi. Traced all lines with no wet spots. The fuel filter assembly and water bowl looks good and full. I cracked the main fuel line at the front of the engine and I can confirm fuel is making it all the way up.
I've cranked multiple 30 second intervals with no hint of firing, no smoke. The cranking of the engine is moving air as the exhaust cover flap is bouncing. I used starting fluid (yes I know) to make sure the engine would fire off on something and it would run for a second on starting fluid but that's it. The engine sounds fine internally but surely no fuel is the issue. I loosened the return hose on the fuel tank to check for return fuel and it was dry. I repressurized the fuel tank but never got a return flow of fuel. I cracked the primer fuel line on the front of the engine and it has fuel so something is stopping the flow.
I've followed the TM's and many other member's posts about the notorious issue of repriming the fuel system. I've looked over the emergency stop lever/shut off solenoid and they are stiff but appear to be in the "run" position. What am I missing..?
