antennaclimber
1,022
State College, PA
I never heard of the "MVPA TMC19 Lincoln Highway Convoy" . Where was this at ? Looks like a desert area.
https://www.mvpa.org/convoys
100th Anniversary of the first Transcontinental Convoy the US Army completed in 1919.
We started in York, PA and ended at the Western terminus of the Lincoln Highway In San Francisco, CA
TechnoWeenie
1,746
Nova Laboratories, WA
Just getting pissed.
My M1031 bench fits me fine. A little tight but completely usable.
I get a 1009, and I feel like I'm in a jeep, with the steering wheel in my ***** and my head hitting the ceiling... what the **** is going on here?
I pulled seats out of an S10 since they looked a little shorter... nope...not enough to make a difference. My leg is getting caught under the steering wheel just getting in and out.... and I've had an M1009 before and didn't have that issue... grrrrr
Got it painted, but now I'm chasing electrical gremlins...
I need to get this on the road... it's my only vehicle..
cucvrus
10,467
Jonestown Pennsylvania
Sounds like you have the wrong pedestals under the seats or the seats are just a bit thick at the bottom cushion. I used Chevrolet Astro Van pedestals and S10 Blazer pedestals. Some minor floor bracket fabrication and welding skills are needed. No alterations to the floor at all. I used 3/8" elevation bolts to attach the brackets to the floor. Good Luck. Making shorter pedestals is fairly easy. Don't modify the OEM CUCV ones. They are hard to come by. The type 1 multi piece ones are the strongest and best ones to have. The type 2 seem to crack out the floor around the anchor points. Especially with a big Bass sitting on them and bouncing around.
royalflush55
547
Reydon, OK
Looks like GM Camper Special mirrors. You can pull the mirrors inside the mounts and then rotate the mirror 180 degrees to make them narrower. They are then inside the extended mount arms.
LT67
507
Bowdon, GA
CAUTION Proceed very carefully in wooded areas with mirrors like that. Reminds me of the Dodges I see on the road with huge stacks coming from the bed. Where did you get them mirrors?
Someone prior to me swapped civi doors and front fenders. Idk why.....
hrbergeron
409
Geographical Center of Virginia
Made progress repainting mine last weekend. Still have to add the camo stripes and lizard skin on the inside this weekend. It's even darker now that it has dried. Originally when the paint went on it looked like Kermit the frog. 71404966_2557012630987718_2728796923073921024_n.jpg72131977_2557012744321040_2679685715800883200_n.jpg71837137_2557401537615494_5767704344778506240_n.jpg
Another Ahab
4,705
Alexandria, VA
Made progress repainting mine last weekend. Still have to add the camo stripes and lizard skin on the inside this weekend. It's even darker now that it has dried. Originally when the paint went on it looked like Kermit the frog. View attachment 778907
Kermit. That'd be a great name for your ride! If you were prone to naming your vehicles, that is...
A second to the motion by rustystud: great looking job.
Not a real painting booth or anything (nice "shed" though, for sure), so how did you handle overspray? A fan maybe? or not at all?
hrbergeron
409
I just had the tarp down. The overspray was already dry by the time it hit the floor so it's like dust on the concrete.
jholler
Jonesboro, AR
Swapped m1009 axles with an m1028 donor I bought, replaced differential oil with 75w90 full synthetic (plus additive in the front), all new front brakes, q78-16 TSL Swampers, waiting on a 6" lift so they'll stop rubbing lol. Added a 12k Badland winch, and next month will do a disc brake conversion in the rear.
