winglift
- 0
- 1
- Worthington, Indiana
I recently purchased a MEP-018A generator from an auction. The information indicated that it had 504 hours on it and the only photograph of the whole generator was just a top view along with a couple photos of data plates. I thought that 504 hours wasn’t too bad and it was the only one that was regular gas powered instead of diesel. I have since discovered that it is noisy and has a high fuel burn rate and the diesel versions were not as noisy and didn’t burn as much fuel as this does, and that is okay with me.
The surprise was after getting it home, I was familiarizing myself with it and saw that the Hobbs meter indicated 504 hours as described, but also noticed that there was another placard titled Overhaul with a stamped date of 06-68 and the Hours overhauled is 504 hours. So this had been setting there in a crate for all of these years right after it had been overhauled.
I have never operated these before. There is still about a 1/4 of gas in the Jerrycan and there was little or no oil in the crankcase. I filled the crankcase with SAE 10-30 oil. It had a 24 volt Titan battery with it, but it was of course too old and there were some cracks on the outside of the case and completely dry so I didn’t bother with using it. I am working on possibly getting a couple Group 51R batteries which seem to fit the battery tray, but would like to find a replacement for the Titan 24vdc battery.
Any advice before I attempt to start this?
