- 2,974
- 4,355
- Olympia/WA
So used it last weekend, it was hooked up to a buddy's Base-X 303 tent. Was enough to keep it comfortable in 90 degree weather in a field, and more than warm enough overnight. Not sure how much fuel I actually used as I put about 40 gallons into the tank on the way there, but everything worked how it was supposed to once we fixed things like the air tubes being a little short and the extra tent material getting sucked into the intake tube and blocking off air flow. Put about 20 hours on it total no problems.
Gen ran at 50-60% on AC, and at 105-110% on heat with only 6 of the 9 heating coils. Also had to turn down the voltage knob to lower the amount of power draw to keep it from tripping when we plugged in things like lights and the projector to watch movies.
edit: tent strapped to the back of the trailer for counterweight is a Base-X 8D32. MUCH too big to work with this little cooling setup, and I don't have the liner for it anyway. It did make it so I could barely lift the tongue before I added the fuel to it. I put some wood blocks to space it away from the air vent on the generator.
