steelcaptain
- 10
- 18
- Mt Vernon, WA
with coolant level low there was no noise coming from the water pump but after filling cooling system all the way, the water pump is making a noise something between a squeal and a grind. noise seems to be at all rpms but as the engine rpm drops, the noise momentarily goes away then returns when rpm stabilizes. coolant appears to be circulating in the system fine. it is not the belts
any thoughts if this is a bad water pump or something else in the front gear drivetrain?
