Fermont 804-B Engine Control Module Needed
WildernessJeep
89
Huntsville, Texas
I'm looking for the Engine Governor Control Module for my 2010 Fermont 804-B with the Yanmar Turbo Diesel, NSN: 2910-01-371-4356. It is also known as a Woodward Controls, part no 8270-1003. I can't find it anywhere, and my generator is useless without it. Anyone have a lead on a cross-fit component or resolution?
Guyfang
24,148
Burgkunstadt, Germany
Your right!
I was looking at an old TM, and when I went to pop the pizza in the oven I reopened the TM file and saw I had looked at a TM from 2002. Sorry.
You can also look under the woodward part number, 8270-1003.
This is also a part number for this governor.
DYNA 10503-001-0-24
WildernessJeep
89
Huntsville, Texas
Your right!
DYNA 10503-001-0-24
Yeah, I can't find that part either. GE aerospace makes one, too, but that's impossible to find as well. Any cross-referenced parts?
Guyfang
24,148
I just looked at all gen sets, 15-60 KW in the A and B models. That governor only fits that gen set. Its not used anyplace else. Is yours bad? Missing?
WildernessJeep
89
Huntsville, Texas
Mine is missing. It looks like someone tried to bolt another component in the same space before the govplanet auction to hide the fact that box was missing (not like I would have known anyways). I bought it not running on the cheap. Now I'm going through part by part, and noticed this missing. That'll cause it not to start, huh?
Guyfang
24,148
Yeah, a little bit. Everything was good with the A models, until they came up with the new engine. AND it needed a different engine. But for some reason it also needed a new GCU. Stupid. Have you listed in the want adds in the forum?
Dewie38
189
Milford Ct
You could use the control unit from an 804A
We had to change engines because the Isuzu engine we were using became unavailable. (out of production) we had to change controllers because the actuators on the engine had a different spring tension and the controller wouldn't respond as the old one did.
It didn't have the same response time so the sets wouldn't pass the freq. and voltage response tests where the freq. had to recover within a certain time.
So if you don't care if the freq. response time is a little slower go ahead and get a controller for an 804A if you can.
Guyfang
24,148
Please be advised, that there is another GCU with a different NSN that will also fit the A model 804A. It was the first generation GCU. The second one, NSN 2990-01-601-2478, (the one listed above) is a newer model, that is called a "universal" GCU. It fits the 804A, 805A and 806A. The old GCU, NSN 2910-01-373-2590 is also in EPAY, and about 200 bucks cheaper.
WildernessJeep
89
Huntsville, Texas
Got the generator up and running today!!! Started right up, runs smooth. Need to finish up a couple of wiring connections and get the distribution box connected up, but overall it sounds great!! Thanks guys!
