JD4044M
- 999
- 93
- Okanogan, WA. 98840
My 2 Rear Tires should be here Tue/Wed this coming week. I figured I would save money and remove the tire & rims myself so I tried today. Removed the 20 lug nuts what a job! I had to use a 3/4" Air Impact Driver. The Tire Shop was concerned about the 40 smaller bolts holding the rims together and air hose getting broke. So I removed them but left 2 loose ones hold it together till I can get help.
Just not sure I can handle these tires yet removing them from the hubs. It weighs more then twice my weight!! If I can get them on my tractor forks I will try to bust one the rest of the way apart and save $100.00+ per tire. I cleaned the parts up on the wire brush and all bolts came loose but 2-Lugs took forever to get off!! No way could I bust these loose with a 4 ft cheater bar giving it everything I had?? I will post a picture later tonight. They used "Blue Loc-Tite" on the Allen Head Bolts you better have a good fitting one also to get them out!
