faststandard
- 50
- 18
- Birch Run/MI
My son and I have been trying to figure out why his M1009 has lost it's ability to fast idle/advance the pump when cold. When we purchased the truck, the old thermal switch was stuck closed and the truck idled fast with advanced pump timing all the time. Fast forward, we replaced the thermal switch with a new BWD part and all was well for a number of weeks until one day it did not idle fast when cold. In addition, he noticed that thermostat housing was leaking.
Well, since we had to drain the coolant for the thermostat replacement, we decided to purchase another thermal switch (local parts store was kind enough to replace the old unit under warranty) and install it. The new one is installed and we checked for voltage at the wire when the key is turned on - everything seems to be correct in terms of function.
The issues that we ran into were on the thermostat housing - the lower bolt broke on us despite our best efforts. Luckily, it did not break flush with the cross-over tube so I welded a nut to the bolt and removed it that way.
What is everyone using for replacement thermostat housing bolts? The old bolt is a M10x1.5x35 with a flanged head grade 9.8. According to the TM parts manual, it indicates GM P/N 11513606 but that part number seems to pull up a non-flanged head bolt in the GM parts catalog. Am I missing something?
Thanks for the help as usual.
