No need to do the battery thing. Just pop the CB1. All the electrical components will de-energize. BUT, there is always a but. it is possible to get bit in the special relay box, when its hooked up and CB1 is popped
Lets start simple. I would suggest testing the A4 card first. Its easier, and you can get a feel for doing this stuff. AND, when you are done, if its good, you can pop the 3 silver relays out of the A5 card and test them. Its straight forward. This is not hard, and you just need to keep in mind it can bite if you don't pay attention.
We are going to do this out of order. The relay test is easier to do, and goes fast. So gather up the relays from the A5 and hold them in ready.
1. take the A4 card out and put it someplace near the gen set. Close to the battery box or the slave receptacle.
2. Cut two pieces of wire long enough to go from where you are working on the A4 card, and the slave recpt. or battery's.
3. Look at, (read) the attachment I added to this post. Go to paragraph d. There it tells you to hook up the wires to terminals #8 & #2.
4. Then stick the two wires into the slave recpt holes or have someone hold them to the main + and - battery terminals. You should hear a klick.
5. This should be K1 relay we are testing. Set up your MM, (multimeter) for ohms. touch the two leads to terminals #7 & #9. You should have NO continuity.
6. This step is not listed in the book, but do it anyhow. Place your MM leads on terminals #1 & #3. You should get continuity.
7. Remove the wires from the slave recpt or battery's. Make the same measurements. You should have the opposite readings.
8. You have now tested the A4 card for the operation of K1 relay. If everything tests right, then good. Then test all the other relays from A5 as well as the K6 relay from the A4 card. This way you KNOW they are all good.
Beer break
Now back to work.
1. Go back to paragraph b. Read it. Take the A4 to your work bench, where I hope you have a 120 volt outlet.
2. Go find something with an electrical plug on it, that you do not need any more. Cut it off, as long as you can. Strip back the ends about a centimeter or so.
3. Connect the ends to terminals #4 & #12. Plug in the plug. This is where you need to take some care. 120 VAC will bite when you don't pay attention.
4. Set up your MM for AC voltage. Place the leads on terminals #6 & #10. It should read 120 VAC. If that is the case, set your MM up for ohms, and measure terminals #10 & #5 and #6 & #11. There should be no continuity.
5. If the measurements are all good, disconnect the 120 volt plug, and retest the terminals. #5 & #10 and #6 & #11. You should get continuity.
If that all worked out right, you have completely checked out the A4 card, and its GOOD.
