nedbread
- 14
- 8
- austin, texas
Hi ,
I have a 1985 M1010 with the 6.2L diesel. It has worked fine since I got it in September 2019, although I did not drive it much and it sat for a few months during that time. Made 1400 mi from Minnesota to Texas with no trouble.
Recently I was told by another owner I met that he replaced his IP and he advised me to use fuel additive.
Shortly thereafter I noticed a rough idle and loss of accelerating power on the road. Pretty quick it just up and stopped going when I hit the gas, so I cruised to a stop and monkeyed with the fuel filter. I did more harm than good and ended up getting it towed to a local shop.
They could not figure it out. They spent a lot of time with it. They replaced the fuel filter (correctly) so it was running again but like before, smoke, rough idle, and no acceleration. They said that the idle-up solenoid was giving sporadic readings and is probably bad. They said they are 99% sure it's the IP because of their diagnosis process.
They quoted me $3,500 to replace a handfull of parts including the injector pump, with 10 hours of labor in there, so I more or less deduced you cant own one of these things unless you do the work yourself.
I can probably replace the IP myself following the manual and such. Should I do that? I read there is another fuel filter in the gas tank called a sock. It looks pretty gnarly to get the gas tank off.
Thanks for any advice.
Best,
Ned S.
Best,
Ned S.
