- 1,504
- 1,169
- TN
Started the M1088 at 14 degrees F. Block heater definitely helped. Started fairly easily. Likely to add oil pan heater.
Someone posted a trans temp chart, indicating the negative impact of higher temps to the trans. Sounds like a bypass might help in warmer ambient temps to reduce the heat soak from the engine. Has anyone done this?
