- 204
- 372
- 63
- Leechburg, PA
I’ve seen some hack jobs but they way they integrated the CTIS wow cut a notch out of knuckle and silicone shut wow.
.OK guys I need some help here I have looked through multiple TMS but can't seem to find the torque specs for the upper and lower kingpin plates the bolts and nuts I believe I found the upper 80-105 but I have looked through TMS on here and the ones I own can't find the lower are they the same as the upper. There going to be if I can't find them thank you.
Swapped out the ancient spare tire for a fresher one that matches the driver's side with new inner tube and flap. The old spare was terrible and out of round but it worked. The shock was toast on that side anyways, so I installed a Monroe for $30. I took a picture of the driver's shock part number for reference if the Monroe craps the bed. I keep eyballing some larger tires like some 11.00x20 NTD or some Goodyear G177 radial or larger, but after wrestling with one wheel by myself.... Heck no!!! I installed a slobber tube since mine was non-existant. I also greased all zerk fittings. I never know huch many pumps to fiill the king pins and trunion bearings? I did 20 pumps for each king pin zerk and 30 pumps for each trunion. 2 u-joint zerks were being fussy, not sure if they were accepting grease, I may just replace them. I love the overkill of zerks, 5 just for the pintle hitch.
I cannot un-see that image in my head.looked like someone had horrible diarrhea and couldn’t find a place to go except in the knuckle
.Upgraded the deuce today with a lmtv step so the 5’2 wife can get in. Now no excuses about not wanting to take it because it’s to hard to get in lol
Cant ever have enough junk rags for that job.I decided to work on Spartacus today lol this is what I’m in to anyone bored lol
