hanselandgretel
- 7
- 8
- Claremont, MN 55924
Where can I find install instructions for hot water heater in an M35 gas duece? Thanks Al Hansel 507-528-2780
Correct, the ductwork and diverter are under the dash. I have installed the entire unit under the dash as well as in between Jeep seats and Deuce & 5 ton bucket seats. We would pull out the bench seat and put buckets in from a GOER or heavy hauler.The water heated heater for the Multifuel M35A2 will work just fine on the Gasser. The heater core and fan sit on a pedestal on the drivers side of the engine under the hood. With ducting going through the firewall to an on/off air flow flapper and a diverter to floor or defrost.
