- 323
- 238
- 43
- Myakka City, FL
Gentlemen; I have a charging problem and it goes like this/ The Battery configuration is 2 group 31 batteries/ The system has been very functional for over a year/ Now I have the 12vdc side draining while it's running and my charge rate on the 24vdc side is acting like the parasitic draws we use to have on the M35's/ The one battery gets drained while the other one cooks/ So on this on I checked if the 12vdc side was charging and I found it is not. According to schematics the one Regulator controls both the 12vdc side and the 24vdc side. I'm not really familiar with how/ But the 12vdc side of the Alternator is reading 12.4 volt and the 24vdc side is reading 28vdc. That is where I draw my conclusion that the 12vdc side is not working. Can it be the regulator since the 24vdc side is working or is it the Alternator???
How do I go about to test this? Is there a test spot to check the Alternator for full load output???
Thank you and I look forward to your responses.
Lugnuts
Lugnuts
