Sweet Rides
- 28
- 13
- Suffolk UK
Hi guys,
Hopefully this is a fairly simple question to those with knowledge of the Sprag transfer cases. I did a search but could not find a definite answer to the following question :
Question - If you are not worried about having any drive to the front axle and you have a sprag transfer case - is it possible to remove the front drive shaft (connecting the Sprag case to the front axle) and drive the truck as normal?
By this I mean that the sprag will not make any issues for the truck and you can change/select whatever gears you like/roll backwards in gear with clutch down/clutch how you like/pull off in second gear etc etc etc - all the things that you would be able to do with an air-shift transfer case.
In this "No front drive shaft" senario the transfer case will not create any issues? Not bind up, not knock. not jam etc? And the two rear axles will drive as normal?
Thanks for clarifying this, it is something that could be useful to a lot of people who have sprag transfer cases and just want to use their Duece for simple, hassle free, on road driving.
All the best!
All the best!
