blutow
- 501
- 63
- Austin, TX
I've got a power steering pump that has a slow leak. I'm pretty sure it's leaking at the shaft. Power steering works fine, so I'd rather not do a new pump if possible. Is there a DIY process to put a new shaft seal in? It's one of the later style pumps on and m1123 where the reservoir is separate. I did some searching and found the shaft seal for the old style pump and seal kits for the steering box, but nothing for this style. If there is a rebuild process (and parts diagram) documented in a TM, sould someone point me to where to look?
