4l80e Wiring Harness Question
Hummer Guy
807
United States Louisiana
Does anyone know where I can get the internal wiring harness that doesn't have the green piece inside? The female end on the outside already has the green piece but with my newer harness, the green piece is on the male end as well so I cannot connect the two.
Image attached is the green piece Im talking about
springer1981
1,150
Maine
Are you sure the green piece on the on your existing harness isn't from the old harness and broken and stuck to the wrong connector?
Hummer Guy
807
This a little off topic question but still on the trans, the bolts for the shifter linkage to the transmission, are those bolts bigger? Mines was completely missing the bolts, it seems like that explains why the whole linkage wasn't in place and the trans had no fluid
