Air Hose Add On
Lugnuts
231
Myakka City, FL
Hey y'all, I have a Fire Department that is wanting to add the availability of air pressure to a hose to fill tires or whatever. I know that this sounds simple but I thought that first I would run it by because I know somewhere out there someone has an incredible idea and needs to share it with the herd. So this is intended to open the floor for such ideas.
At a Fire Department anything that can be broken will.
I am looking forward to the ideas. Thank you and I almost forgot/ M1078/
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
$70 reel, 75' of hose from tractor supply Hook it in at the wet tank and put a shut off valve on it.
If they want it down low just bolt it to the frame in front of the exhaust.
INFChief
1,345
New York
You could fit the supply end of your air hose to a glass hand and simply attach it when you need to air something up.
Ronmar
7,224
Port angeles wa
Yep, I believe this was actually a tool kit item. You connect it to the rear red glad-hand and turn on park and trailer controls to send air to that glad-hand… you of course need to chock the wheels or have someone in the cab to hold the brakes when you do this.
I made up one of these initially to feed my plasma cutter(truck is a great dry air source:))…
simp5782
9,339
Mason, TN
Why I have 35gal total on my 920 with a 10kw hydraulic welder/generator to run my hypertherm 900 on the side of the road.
Third From Texas
6,465
Corpus Christi Texas
I made my own but have never really used it. Been a couple years and I don't recall the specifics, but the truck has to be running and in neutral with the brakes off or something for it to work. Whatever it was always made me a bit nervous on any surface with a grade and I never have a co-driver with me to mind the cab while I'm out of it.
Ronmar
7,224
Port angeles wa
Yep, The tap off the wet tank is a little easier to use…
