no such animal at the momentAnyone know where one can get a well priced radiator and fan for a 6.5 Turbo, M1165A1, with 256000 serial?
Yes, IF and I mean IF (has not been vetted) you cannot get them boiled out anymore than what? you spray some "stuff" in there? re-core or new would be a better option...Without testing and "as-is" is a big problem. I will probably recore mine
You realize any of us can boil out a radiator with warm water, a little dilute plumbers acid, and a chemical resistant hand drill operated liquid pump?Yes, IF and I mean IF (has not been vetted) you cannot get them boiled out anymore than what? you spray some "stuff" in there? re-core or new would be a better option...
Maybe but what they used to use looked like pure evil, it looked like a good place to get rid of the mother-in law, weren't no fizzy soda in there...You realize any of us can boil out a radiator with warm water, a little dilute plumbers acid, and a chemical resistant hand drill operated liquid pump?
I even wonder if Pepsi soda pop or table vinegar will also work.
Champion finally has them listed on their website. You can either search for ECV or go directly here...I've been working with Champion the last month or two to get an aluminum aftermarket replacement in production for the ECVs. They are currently building the prototype, and should be in production shortly after the prototype passes. Unfortunately that may not help you now, but help is on the way. I'll update this thread again when I get further info on production dates.
