springer1981
- 1,150
- 93
- Maine
Twice the PSI = twice the MPGYour pressure monitor is measuring psi, not percent and why are you trying to put so much pressure in your tires anyway? I normally only run mine at 45 psi and an unloaded M998 usually only runs 25 psi per tire.
That's way less funny though...you know this whole thread is a joke right?You can accomplish the same thing with a 10% overpressure and not risk a high speed blowout that could cost you your life.
Have you priced Helium lately?? Sheds more than 20 pounds from the wallet LOLI prefer helium... sheds about 20 lbs of tire weight.. Its quite an elevating way to air UP
don't the smaller molecules also leak out faster through the pores in the rubber?I prefer helium... sheds about 20 lbs of tire weight.. Its quite an elevating way to air UP
