oddshot
- 119
- 43
- Jasper, Georgia
My M35a2 has had high oil consumption since I bought it 10+ years ago, about a quart in hundred miles. The engine starts and runs great, idles fine and has plenty of power. No odd noises. It does smoke, black smoke, on the road, but not much sitting still. It smokes more than some but not as much as others.
The truck is a 68 that went through the rebuild program. I bought him with 12,000 on the odo and now he's up to about 37,000. Never run hard, never overheated. It's got a couple little leaks, but not much to talk about. Barely leaves a drip in the driveway. It's NOT blowing oil out of the exhaust.
As I recall, it's got a D turbo on it. Unfortunately, I had a computer crash and lost ALL of the logs and records I kept on this truck.
I've always been suspicious that it has a leaking turbo seal.
I'm a life long auto mechanic, service manager and shop owner. I have a degree in AUTO (not truck and not military trucks) tech and my ASE certs, so actually doing the work shouldn't be a problem. I do have questions.
1. Is my oil consumption related to the turbo? My thinking is there is no way to find out. If the leak is on an "inboard" going to engine side, I don't think that there would be a trace of a leak, the pressure produced by the turbo would just blow the oil into the engine.
2. Will this engine run OK without the turbo? I've been led to believe that the only reason the turbo was installed was to reduce smoke signature ... not for more power. Can these things simply be removed?
3. I've done a bit of searching and read that parts for the turbo are hard to come by. Does that include turbo seals?
4. I've never rebuilt or resealed a turbocharger. We always sent them out for rebuild or installed a new one. Come to think of it, the only modification I have ever done related to turbos, was the installation of a RUF twin turbo kit onto a 930. That has got to be over 30 years ago. Is a seal replacement something that I can do without a lot of special tools.
And finally the big scary question:
5. Could I be risking a "run-away" given the high oil consumption?
I would really appreciate any advice, suggestions or help you might share.
