Another question for the experienced folks here. As I mentioned on my other thread, I recently installed a set of skid pads from Jeremy Johnson. He certainly does great work.
I mentioned that when I turn the steering wheel all the way to the right stop, the right outside of the right tire rubs. What is strange is the same tire does not rub at all on the left side at all when the wheel is turned the other way. Neither tire does not rub on either side when the steering wheel is all the way on the left stop. The left tire does not rub in either position.
Looking at it carefully, it appears to me that the left tire sits further forward in the wheel well than the right tire, which seems to be further towards the back.
Before I go an cut the pretty powder coating on Jeremy's skid plates, could this be an alignment issue? I am no alignment expert, but I don't see any eccentrics on the lower or upper control arms, but what do I know!
If it is an alignment issue, my next issue is finding someone that would be willing to align it. Can someone please point me to the alignment specifications for an M998 so I can bring them with me if I do find someone.
Thank you for you wisdom
EDIT: I googled the alignment specs: http://www.hummerknowledgebase.com/susp/specs.html
HUNTER HUMMER ALIGNMENT SPECS
1992-1995 All Models (Unloaded)
2000 Models, see below
LEFT FRONT | RIGHT FRONT | LEFT REAR | RIGHT REAR | |
CAMBER | 0.8 -> 1.3 deg. | 0.8 -> 1.3 deg. | 0.8 -> 1.3 deg. | 0.8 -> 1.3 deg. |
CASTER | 0.8 -> 2.8 deg. | 0.8 -> 2.8 deg. | n/a | n/a |
TOE | 0.0 -> .03 in. | 0.0 -> .03 in. | 0.0 -> .03 in. | 0.0 -> .03 in. |
