Questions about uparmored windshield frame compatibility
Westo
Seattle, WA
I bought an M1114 recently and am now waiting for EUC. I've been looking at my windowless and mirrorless frame, and trying to figure out if things will fit. The mirrors mounted to the armor so I know those won't fit, is the solution just to drill new holes in the frame? Or are there aftermarket brackets that anyone knows of to fit them? For the windshields, it looks like regular ones might fit in, but I'm not sure. Also not sure about the situation with windshield retainers. If anyone has experience with this or ideas please let me know. Picture of the frame from the planet attached.
Westo
Seattle, WA
Congrats!
I asked the same thing about the windshields here and there is some useful information. https://www.steelsoldiers.com/threads/just-won-a-m1152a1-and-have-questions.213365/
As for the mirrors, on mine have rivnuts where I think the mirrors go... and I ordered new NOS ones but have't installed them. but I think the will fit
It looks like the later model uparmored ECVs still had holes for mirrors and retainers. Comparing the bolt patterns, the M1114 definitely has none of the holes for that stuff, so I guess I'll be doing a lot of drilling.
Westo
Seattle, WA
This is the only diagram of the windshield assembly in the M1114 parts TM, but it seems to show a normal looking frame with all the mounting holes in it. I also found this one, which is a retainer design I've never seen before but still seems to use the same holes I'm missing.
Westo
Seattle, WA
I'm basically using the forum as a journal now, but I think I figured it out. the second diagram is correct, but the holes used in the retainer were actually on some piece of armor that has since been removed. That still leaves me without a proper way to mount stuff, so any suggestions there would be appreciated.
Coonass77
179
33
North Carolina
The normal hockey stick, center and lower windshield retainers work fine. You just need to drill holes and install rivnuts, using the retainers as templates. Normal mirror brackets also work fine, I just had to drill and rivnut those too.
spankybear
884
WA
I have a set of thin retainers (hockey sticks) and the ECV retainers. I can use the ECV retainers as a templet to drill up the other set... if you are interested. The ECV set is about 100 bucks and the normal ones about 35 a set.
