Folks,
My luck just seems to be going from bad to worse. I am working two different AC problems in different threads and now another horrible issue developed.
When starting the engine I heard a horrble grinding sound while cranking. I get under the truck and pull the Torque Converter cover, and low and behold I now see some teeth missing on flywheel! This is after I finished a TH400 to 4L80 a couple months ago. So I get to play again!
I am hopeful I can just disconnect the driveshafts and push the 4L80 back a few inches to get enough clearance to pull off the flywheel without dropping the tranny completely.
I have two questions.
Thanks in advance for your experience.
- I see a wide range in pricing for new flywheels. As low as $70 up to $200. I assume the low end ones are cheap chinese crap. I think the part number is 2815011483771. Anyone have a recommendation for a source of a US made one? I don't want to end up paying for a $200 and end up with a cheap chinese one! Maybe a real GM generic part? Will a GM part number 14077157 work in a HMMWV? I see Rock Auto has a GM OEM one for $140 shipped.
- Regarding the starter. What is the recommendation? Replace, or take a chance and run the current one and risk tearing up a new flywheel?
