Well I give it a try today. That sucker is tight. I was able to get a crows foot wench on the fuel line, but I couldn’t get one on the cap because of all the injector lines. I had to put a 3/4” end wench on it straight out. Then an adjustable wench on that and twist. Obviously, not the best set up, but I still could put some serious torque on it and no joy.
I sprayed it good with pb blaster and tapped it with a hammer and bar. I will try again tomorrow.
Question, did you have to completely remove the Allen lock foot thing? I backed mine out more than an 1/8”. Doesn’t seem like it could interfere.
While I had the fuel line off, I stuck it in a bucket and cranked the engine. I believe they say a pint in 30 seconds. I only cranked mine for 5 seconds, but I have no doubt it will pump a pint in 30.
Second Question, would I be crazy to put compressed air to the overflow port and force the fuel in the pump back through the screen backwards? Seems like it might force the dirt out.
