Been troubleshooting a lighting issue on my, new to me, M998A0. Hoping the collective knowledge here can accelerate my process. Found a couple very helpful threads, linked below and been working my way through the TM's. Hopefully, one of you can point me to a common gremlin or two I can check on.
Here's what i have done. Installed new grounding harness and cleaned up all grounds it touched. Generator is charging fine. Truck starts/runs/drives fine. Dash lights, wait light and brake light work as expected. I have tried two new Tri-Switches, made zero difference. Continuity through them is fine for all positions. I have 24v at pin F on the connector to the tri switch. The tri-switch plug is clean and in good condition. I opened up the tail lights, bulbs look ok. I do not have voltage at the lights.
So far the troubleshooting is pointing met to the PCB or tri-switch. Tri-switch seems fine and PCB is giving me 24V at pin F.
Any thoughts? Thank you in advance for you help.
HMMWV A1 Troubleshooting | SteelSoldiers
m998 no lights | SteelSoldiers
HMMWV no lights at all ??? | SteelSoldiers
