M977 HEMTT
Karl kostman
893
Fargo ND
Hey guys I cannot believe this but I am having a hard time finding a Radiator cap for an 1988 M977 HEMTT, Eastern doesnt have any and I seem to be striking out elsewhere also? The truck has a General Thermodynamics model 816A radiator core in it and its original all I need to finish this unit is a new radiator cap. Does anybody have some suggestions on where to acquire this piece?
Thanks much Folks
Karl
chucky
18,965
TN .
Thanks much Folks
Karl
Do you have any big truck scrap yards near you if so just walk around and get 4 or 5 in your pocket and one is bound to fit ! Or measure your inlet opening and go to the local auto parts and have them match it !
19,766
Thanks much Folks
Karl
I have what may be a silly question Karl... Do you have the old cap? Thinking that if you did, it isn't anything special. Not military specific. All you really need is to know what pressure "pound rating" the cap has.
Hopefully?
Guyfang
24,067
Burgkunstadt, Germany
Never mind. Found it
NSN: 2930-00-789-0117
Part numbers
12960A
26084-6
5197679
66853bX
AAX0851
B107480
B166667
Tech info.
GRIPPING ACCOMMODATION TYPEKNURLED
OUTSIDE DIAMETER4 INCHES NOMINAL
OVERALL HEIGHT1 3/8 INCHES NOMINAL
END ITEM IDENTIFICATION2320-01-304-2277 AND 2320-01-304-2278 PLS (PALLETIZED LOADING SYSTEM)
SYSTEM FOR WHICH DESIGNEDPRESSURIZED
SEALING LENGTH0 109/200 INCHES MINIMUM AND 117/200 INCHES MAXIMUM
CAM QUANTITY2
PRESSURE RELIEF METHODMANUAL
MAXIMUM WORKING PRESSURE8 POUNDS PER SQUARE INCH
FEATURES PROVIDEDBREATHER HOLE
FILLER NECK DIAMETER FOR WHICH DESIGNED2 67/100 INCHES NOMINAL
MATERIALSTEEL OVERALL
SURFACE TREATMENTZINC OVERALL
STYLE DESIGNATORINSIDE CAM TYPE
