cucvrus
- 10,265
- Jonestown Pennsylvania
As much as I wanted to slack off, I just couldn’t do it. It wasn’t raining and it was fairly comfortable, so I aligned the front-end sheet metal and doors. The doors were fairly easy the driver's door I had to remove and loosen the bottom hinge on the cab. The door had 4 bolts tight, and the others were rusty and 3 were metric and loose. I dug and found a few correct bolts greased the threads and ran them in. They are self-tapping bolts, so they done their job as designed. The right fender required a few shims and a correct greased bolt to be run in the bottom of the fender. I also adjusted the core support right to left and tightened that down with all new hardware. After I get the hood cable attached to the latch, I will adjust the back of the hood. It seems a bit high at the cowl. All in a day's work and I am done for the day. The sun went down on me and the outside light came on. Today is over for me. Take Care and Be Safe.
