Defcon-1
- 56
- 18
- South New Jersey
Hello and Good Day Gents,
Just to preface this, I am in the TM (9-2320-272-24-1 section 3-150 “Coolant System Maintenance” so I have the Technical portion of the process in-hand. However, I have a few questions regarding the coolant system and am requesting some advice / wisdom from those who have the experience, thank you. I want to install a block heater on my M923a2, so at the same time I thought it would be appropriate to drain and flush the entire coolant system, so my questions are regarding the coolant flush. The block heater install looks pretty straight forward, but the coolant flush there are some things I’m wondering about…
Any help or advice is appreciated, ty!
- What type (and I’m talking about brand-specific) of anti-freeze should I be using to meet the 16-quart requirement (per the lowest temp in my region at 0’ F)? This is my first diesel vehicle, so I’m not used to anything that has those protection elements in it, not really sure what to use as the anti-freezer additive.
- Is it appropriate to use something like Thermocure / Prestone Cooling System Cleaner to aid in the coolant flush? Is that worth doing because I see that those products only treat up to 3 gallons, they are kind of expensive so would I need to get enough to treat 11+ gallons worth for the entire coolant system?
- When I do the system flush with water, (fill and drain), can I just use garden-hose water or do I have to fill it up with distilled water each time? This is not to keep the water in the engine, I’m talking about specifically filling up the system, running it for a little bit, then immediately draining it out to get all the debris out. I know I have to fill it with distilled water to run it long-term, but wasn’t sure if adding regular water (temporarily) would harm anything?
- Down the road, let’s say I have to top off the coolant system. Is it ok to add Prestone 50/50? (Related to my inexperience with diesel engines)
- Are there any additives I should be including into the anti-freeze / distilled water (final) fill up? Anything to further help protect the coolant or engine? I read something on another thread about a SCA from Fleetguard? How much of that do I need? Again, this is related to my inexperience with diesel motors.
- Are there any plugs on the engine block that I need to remove to assist in draining the coolant? The TM only mentions the radiator drain valve and the aftercooler drain, shouldn’t there be a low-point drain on the engine block itself?
