- 634
- 947
- 93
- La Crosse, WI
Big IF is if the pressure sensor is accurate.Mine runs about 7PSI when deflating. 5.5 seems a bit low and closing in on the point where the wheel valves close… If you held a little pressure on that relief with your fingertip, you should see an increase in that deflate pressure…
