MEP005A frequency meter not working.
yohanusmarcus
36
Hayti missouri
Start here:
1. Remove the jumpwer wire between TB101-3 to TB101-9
2. Oil pressure switch. Take the plug off. Insert a paper clip in pins A&D.
Start the set, and see if the set runs after you let go of S2.
If it runs, you need a oil pressure switch.
If it stops:
3. Hook the oil pressure switch back up.
4. Unhook the Water Temp switch. Insert a paper clip in pins A&D.
5. Start the set, and see if it runs after you let S2 go.
If it runs, you need a Water temp switch.
If it stops, you need to check the A5 card for K8 working correctly.
Turn to page 5-26. in the -34 TM. Read from paragraph #16 to page 5-28, paragraph #19. Its not all that hard. If the board is bad, Member @kloppk makes a replacement board that is nuke proof.
Ok I disconnected the oil sensor
Guyfang
25,873
Burgkunstadt, Germany
What missinjg part?
peapvp
1,344
Basehor, KS
I thought as much. Am I wrong in seeing the temp sensor bellow the lower radiator hose? There are no other sensors with Canon connectors other than the speed sensor.
There is a temperature sensor connected to the temperature gauge on the front panel.
Then there is a temperature switch which has two wires.
