OrangeElvis
- 44
- 18
- Liberty Hill, TX
So, head-scratcher here. I double-checked and yes, the light stays on when ignition/run switch are off... but BARELY. I took pictures with it fully lit with ignition on and switch set to run (but not started) and with everything off (portrait photo is ON & landscape photo is OFF):...
There's no relays behind instrument panel...only circuit breakers.
That 1097A2 has a relay behind battery box inside of panel which is 24v activated and routes 12v to trans computer...relays do stick on sometimes
with Ignition turned off.
Trans light forward of shifter turns on when ignition is turned on....and should shut off when truck is started or shut off.
If light stays on when Ignition is off...relay is sticking on.
What color is label and box under dash.....Start box ?
![1000006040.jpg 1000006040.jpg](https://www.steelsoldiers.com/data/attachments/674/674918-93a60fbd4871a191375818d18f93d12d.jpg)
![1000006039.jpg 1000006039.jpg](https://www.steelsoldiers.com/data/attachments/674/674920-d298aea53a10d5f04e7354cdcf166727.jpg)
What does that even mean? It is BARELY stuck open, lol? Is there a way to "unstick" it - some kind of reset button?
Also, I am guessing this is what you meant by "start box" under the dash?:
![1000006037.jpg 1000006037.jpg](https://www.steelsoldiers.com/data/attachments/674/674921-411a9e44176368754a8f3c8cdef12ed4.jpg)
