M998 TRANSMISSION
crown3412
Vermont
what type of tranmission is in a 1992 M998 with a 6.2 engine and 3 spped trans? and is it the same as a transmisson found in a civilian vehicle with same transmission?
also is there a cooler inside the tranmission?
TOBASH
3,408
Brooklyn, NY
There are free technical manuals TM’s on this forum brother. Take a few to download them. There starts your road to salvation on all things HMMWV.
Members are always happy to answer questions, but this also gives you tools to read. Confusing at first. Hang in there.
Welcome!
TOBASH
3,408
Brooklyn, NY
Civilian Turbohydramatic 400s have park.
The military unit is exactly the TH400 unit BUT it is missing the transmission park lock. You can add it to your transmission should you choose.
FlameRed
481
Florida
There are some excellent threads here on the transmission options. It is common for us to convert to a 4L80 as you get Park, plus the ability for higher top speed.
TOBASH
3,408
Brooklyn, NY
Requires a minimum of new torque converter, new flywheel, new driveshafts, new 4L80e tranny, new shifter with new shifter shifter rod mechanism, new tranny crossmember support, new aftermarket custom programmed computer control for tranny, miscellaneous wiring.
I did a 700R4 swap on my old M1025. New torque converter, new flywheel, new shifter and tranny rod mechanism, no change of flywheel or computer or crossmember. If you get the shift down cable wrong you will torch the tranny.
I suggest you keep your rig as-is and sell it and then purchase an ECV from RWH. You will save money in the long run.
