goldneagle
- 1,067
- Slidell, LA
Sorry doors are glued in. The differentials were quite a project. Had to drill a 3/4" hole through the center of a 1" dowel. I then had to sand the ends at a 45 degree. Insert a 3/4" dowel that has a 1/4" hole in the center. Then cross drill a 3/8" hole throw the assembly for the axle shaft. Luckily they both came out great on first attempt..
Wow! Even has springs (stiff, but they are there) and the hogs heads and drive shafts... And the doors are even going to open? Really neat!
