Captainscall
- 15
- 3
- Springfield IL
Hi All,
This is my first post. My new to me MEP 831A has me stumped. It starts quick even in the cold. But it billows tons of black smoke, the governor arm has to stay WOT just to keep it running. After 2 min or so the muffler glows orange and backfires really loud with flames out the exhaust. Which at that point I usually shut it down.
So far it has new batteries, filled with fresh fuel and verified it has good flow to the injection pump. I went ahead and disassembled the injection pump cleaned it and reinstalled it. I pulled the injector with the fuel lines still attached and cranked the engine just to see the spray pattern. Injector visually looks like it is working fine. I checked the intake and exhaust for restrictions and they look fine. Engine runs exactly the same after all of that.
At first i was hoping it was just a governor adjustment or speed controller but running the governor by hand i can tell it will only run if it is held wide open.
I will try and post a video but I am new at this.
Thanks for your help!!
