McSpeed
- 293
- 63
- Palmer, AK
AH...this makes sense. Per that posted manual, this explains why the fan kicks on and off. I usually notice this when I'm cruising at 55 or so. This summer I've been using the truck to take my boat to the lake. I'm on the throttle pretty steady to keep it pulling, which may have it in kick down mode. This is why it goes on and off:
B. TIME DELAY MODULE TESTING
a. Description
The time delay module sends a delayed
signal to the fan clutch solenoid for delay
of fan actuation to provide needed
horsepower for engine acceleration. During
normal engine operation [(engine coolant
temperature below 230°F) (110°C)],
current flows through the time delay module
energizing the fan solenoid circuit This
provides hydraulic pressure to overcome
spring pressure thereby disengaging the
fan clutch.
When engine coolant temperature exceeds
230° F(110°C), current is interrupted by the fan
temperature switch. This interruption of current
causes the time delay relay to open, thereby
de-energizing the fan solenoid circuit and
allowing the fan to engage for additional cooling.
If the kickdown switch is actuated during fan
operation, the time delay is activated,
disengaging the fan for approximately 20
seconds and providing additional
horsepower. If the kickdown switch is
activated again, an additional timer within
the time delay module prevents the
disengagement of the fan until 20 seconds
has elapsed allowing for adequate engine
cooling. After the timer completes its 20 second
cycle, the kickdown switch can be reactivated
and the fan will disengage, providing additional
horsepower.
a. Description
fan clutch.
horsepower.
