Took the 1151 out for a spin to the local coffee shop this afternoon. Still makes me grin
to drive it.
NATO plug adapter for the battery tender works great. Very convenient to top off the HMMWV and MEP batteries.
Replaced several injector return lines this evening. For some reason the German made line from Badger Diesel is not holding up on this truck. They have only lasted a few months to date despite being diesel rated.
RETURN of the RETURN LINES
Return lines headaches.
Here's the POOP from my experience on the fancy, green or black, no clips, slip on, with a woven outer jacket, general web sites kits or bulk lengths. At first this magic hose seemed to work... but I had my doubts, old school guy here, time will tell, give it a try ???
A couple of years and the leaks will show up as been my experience. The ends fray, hose splits at the injector barbs, seems to rot and the cabin fills with diesel fumes while it drips on the exhaust. This played out on a return trip camping. It is not the first time seeing this on rigs the boy's and I run. CUCV's and HMMWV.
I carefully cut the braid back to get a good look. It does fray and detaches near the ends. I never had an issues with the OEM and clips... even on 30 years old engines. Do it right or keep the fire extinguisher handy. YMMV... but I'am DONE with easy magic hose.
A little note: Make the loops a bit longer so when they do go to hell... cut off an inch and go another year or two.
Funny this came up, cuz just received 12 feet of viton and changed out all of the crap hoses on three rigs. YEA, the clips are a bit fussy to wrestle with, but not bad with the right tool.
Close up of the ends. The weave is not well bonded to the hose and will separate. Here I peeled it back to expose cracking.
AC Delco GM 14066305 hose and clips 1238007 for factory or DIY... McMaster-Carr, Viton hose 5119K41 $5 a ft and matching clips 25 pack 7329K31 $3 bucks. Double check those numbers. And you paid how much for a HMMWV ??
That's been my experience with easy ass hose.
Good stuff and Good for another 30 years. CAMO at Camoteksystems.
