Michael
- 24
- 38
- Fulton, MS
I though I would post my solution to stuck inner lug nuts. I used the geared lug nut wrench on the outer nuts with great success. That thing sure takes the work out of that job. My trouble started when I got to the inner tire. Nothing was working. I couldn't figer out how to use the torque multiplier wrench either. I came back to the list and did a search and still didn't find an answer. This is what I finally came up with. Probably not the safest solution, but it works. I used a pipe wrench to stabilize the outer part forcing the inner part to turn. Now I need a better cheater bar. The tire tool I was using was barely up to the job.
