Michael
- 38
- 48
- Fulton, MS
I have finally gotten around to working on my overheating truck and thought a good place to start would be to change the thermostat. At first I didn't think it had the rubber seal that you are suppose to remove and replace, but now I am not so sure. The TM pic looks like a split ring, but the picture from the other post looks like what I have which looks to me like a brass ring with rubber underneath it? Kind of like an axle seal. I decided to test my old thermostat against the new one form NAPA. The old one doesn't seem to open up as wide and closes quicker than the new one. But is there enough difference to make a truck over heat? I think I am going to replace the hoses and I may just go ahead and get the radiator rodded since it is half way off anyway. Is is OK to just get NAPA to cut some hose to length or should I order new ones from a vendor? Any recommendations?
Link to the overheating thread:
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=23450&highlight=
